Old July 10th, 2019, 17:05
md21722 md21722 is offline
Door locks randomly lock and unlock while driving
I have an 01 XJ with 378,000 miles. Recently the door locks have started to lock and unlock randomly while driving. Some days it won't do it at all, other days it will do it randomly while driving. Any tips or suggestions on what to look for in troubleshooting?
Old July 10th, 2019, 21:53
lawsoncl lawsoncl is offline
Re: Door locks randomly lock and unlock while driving
Check the wiring between the door and the door frame for frayed or damaged wires. Start with the passenger side as that's the "master" switch.
Old July 13th, 2019, 22:06
RCP Phx RCP Phx is online now
Any update on this? My 2k just started un-locking yesterday!
Old July 14th, 2019, 05:48
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Failure of the drivers door wire harness is very common. Power door locks have 12 volts at all times, so a short to ground will often trigger the lock solenoids. The damaged wires and failed wire splices are most often at or near the rubber boot.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Originally Posted by soyjer
Tim MAY be 100% correct, but why would a person automatically pick him as the expert .....
Old July 14th, 2019, 08:24
Thanks guys - no update - I haven't tried to fix it yet.
I figure I'll try to tackle the passenger window switch problem at the same time. The driver switch switch makes the passenger side window go up and down, but intermittently the passenger side switch cannot make its window go up and down. I've long figured that was wiring in the door.
Wasn't sure if the random door lock/unlock was a computer starting to flake out or wiring but you all have steered me in that direction so I'll try to fix both at the same time.
Old July 14th, 2019, 11:33
trippled trippled is offline
The relays for the door locks are part of the passenger side switch. Random locking and unlocking is often a failed switch assembly. I've been trying to figure out wife's 99 door locks, had the switch apart and then when I plugged it back in they had a mind of their own.
Power Door Locks- Unlock but Won't Lock IslanderOffRoad OEM Tech Discussion 7 May 15th, 2019 13:21
Power-door-locks open... Will then not lock Crist Clapper OEM Tech Discussion 4 February 23rd, 2018 05:43
Another Door Lock/Unlock Question LKN_xj OEM Tech Discussion 8 July 17th, 2016 15:59
Rear hatch power lock will unlock, but not lock... jonathanc OEM Tech Discussion 6 October 21st, 2010 12:04
Sourcing door locks and rear lift gate lock. 89LimitedXJ OEM Tech Discussion 4 September 14th, 2005 07:48
