Old March 8th, 2017, 21:21
Gunter's Avatar
Gunter Gunter is offline
Post wobbly steering box
asking for steering box plates to fix mah junk.
i dont want to do a full rail plate. just a bolt in plate for teh steering box area--
thanks for the help !
Old March 9th, 2017, 06:54
Cottontail's Avatar
Cottontail Cottontail is offline
Three-De Off-Road
Re: wobbly steering box
Taking about the spacer? If so just do a google search. Lots of the vendors carry them.
Dirk DeYoung--Member #176
You'll never leave Harlan alive.
1996 ZJ (200GRND)...2001 XJ (TRALRIG)...2006 XK (TOW RIG)
Old March 10th, 2017, 17:18
rum_maximus rum_maximus is offline
I've got this: DirtBound Offroad Steering Box Spacer - Jeep Cherokee XJ
Throw in code 91WWWHFT and you might get a discount if it's still valid.
Old March 10th, 2017, 17:47
trippled trippled is offline
I just installed the c ROK spacer on mine with sleeves. Outside of my frame was already plated. Fit was awesome and a high quality part. Slightly more expensive than others but would buy it again.
Old July 10th, 2019, 01:45
Gunter's Avatar
Post Re: wobbly steering box
from the old dead thread dept.
i used the steel box spacer, the outer 1/4 in plate and the heavy duty tie rod to fix my steering. all Iron Rock Offroad parts.
my YT channel.
https://www.youtube.com/watch?v=51VOHI2PN4s&t=5s
Old July 10th, 2019, 01:51
Gunter's Avatar
Smile Re: wobbly steering box
and my intent was a better steering set up and easy rebuild and parts availability. and it stopped my DW situation. the track bar is user rebuildable on both ends. steering is stock except the tie rod BUT all tre's are stock.
i also went with
Falken Wildpeak AT3W all_ Season Radial Tire-33x12.5R15 108R for my tires and 150 to my door. and free shipping.
yeah i know, it is not so dazzling but it is damn reliable and easy to repair. and it killed my DW
Old July 10th, 2019, 02:00
Gunter's Avatar
and was about 180 dollars.plus the tire
Wobbly Tilt Steering Saudade OEM Tech Discussion 4 June 3rd, 2015 04:29
Wobbly in the warm, Solid in the cold? Hotwire Modified Tech Discussion 18 April 6th, 2013 21:58
The wobbly-shake-vibe N2L 96XJ OEM Tech Discussion 12 August 8th, 2011 19:03
wobbly at 50-55, yes I've searched yossarian19 Modified Tech Discussion 11 June 18th, 2010 14:41
wobbly steering y-townxj OEM Tech Discussion 5 August 30th, 2005 08:10
