Hot lips for sale
karstic
Milwaukee
1992 4-door
245k on the engine/trans, 33 MT/R and 15" Crager Soft 8's, matching spare and wheel
Hybrid Exo/Internal cage, tied into frame stiffeners and rock rails
MORE front bumper
Warn M8000 winch with Viking synthetic winchline
Dana 30, 4.88 gears lunchbox locker
Vanco big brake kit
Currie Steering
Currie reinforced diff cover
reinforced passenger side UCA mount
Dana 44 4.88 gears, Detriot locker, Ruffstuff diff cover, drum brakes
RE Superflex Short arms on drop brackets
ACOS spring spacers/bumpstops
JKS Disconnects
Deaver rear springs
JKS extended shackles
Bilstein 7100 shocks. Front axle modified for lower shock mount, JKS upper adapters. Rear axle mounts raised, upper mounts to cage.
231 Transfer case with Advanced Adapter SYE and Tera 2 low shift kit, correct speedo gear for gear/tire combo
Beard seats, Beard spare tire strap
Mopar gas tank skid and class3 receiver hitch
Hella 500 driving and fog lights
Hella horn
New Sears Die Hard AGM battery
upgraded battery cables
New catalytic converter ready to be installed
Title in hand, non-op
$3000obo
AW4 Trans? Or AX-15?
Is there anything besides the cat keeping it from Kalifornia approval?
Sounds like a really good deal for someone.
right? you can barely get a stocker for that anymore.
You got that right.
If it were white with an AX-15 I would be in heaps of trouble with The Bride right now.
AW-4. A bit on the smog history, last time I took it in for smog it barely passed the sniffer test but failed on visual. It has a Gibson Stainless steel header with a bad collector. The tech failed it because the EO number wasn't on the header but I have the sticker. I should have brought it to another station. This was three years ago. I have a new California legal cat for it (not installed).
Sent from my SAMSUNG-SM-G930A using Tapatalk
Yeah, it helps to put that sticker on the firewall.
Tim. It is. The tech was kinda an ahole.
TSA complex. Hate those people.
I started reading the info and then saw the price and was thinking, Man I need to go to So-Cal where this is and buy it. Then I saw it was posted in 2017. lol
