Black1990jeep
- california
My 1990 Cherokee had a lot of modifications done by prior owner. I am in need of finding out what parts are what, what part numbers are for replacement bearings, seal and such. Also Id like to know if any of these modification parts came stock on other vehicles such as a Wangler or what ever, as that would help me in ordering replacement parts.
For the front I have the stock Dana 30 housing. An ARB locker. I have Warn Premium Manual Hubs, 5x5.5 in lug pattern. The outer or stub axles are 30 spline, they have a U Joint knuckle, the cups on these UJoints are 1.19 inch O.D. The inner axles are 27 spline.
What if any stock vehicle are the these parts from?
What is the UJoint part ID for ordering a replacement? ie 1.19 inch cup outer diameter.
What about bearing part numbers?, Oil seals?
I have no instruction for the hubs, any source online for them?
I probably need new stub axles too, bearing race is worn for the hub needle bearings.
Thanks for info!
Thanks for info!
