D-Rings & Brackets w/ OEM front bumper?
BALTANAKT
Berthoud, CO
Hi all,
Curious if anyone makes a set of D-Rings & Brackets that would fit below the stock front bumper?
Not having any luck searching as of yet. Hi-Country, who went out of business, used to make them.
Thanks
I made my own D-ring brackets and bolted them to the factory installed tow hook brackets. I suppose you could find a pair of inexpensive receiver hitch shackle inserts and convert them by drilling two bolt holes.
If this is for looks only you could fab something easily. If your intent is recovery, then you need something that ties both sides together along with additional tie-in's. A front hidden hitch is a good choice.
Iron rock offroad makes sense nice setup. It's almost like a front hitch but designed for d ring shackles
Sent from my SM-G955U1 using Tapatalk
Good to know.
Any recommendations for maker?
Will a front hidden hitch work with a front skid plate?
