Any recommendation on a muffler shop in Santa Clara/Sunnyvale ?
Slonopotam
NAXJA Member #1358
San Jose
Hi,
My muffler has a nice hole in its belly, time to replace. So a few questions.
1. Can you recommend / black mouth a muffler shop in Sunnyvale/Santa Clara ?
2. Is there any ghetto fix, like wrap the muffler around with something easily available from OSH to silent it for a couple of days. I would really hate to drive it like that.
3. Since I am already doing it, what is the most quiet cat-back system among hi-flow ones ? I already got a "hole-in-the-muffler" hi-flow system, but it is very loud :). The best would be if I do not hear it at all.
A link to any sort of noise measurement data is very much appreciated.
If you want a shop, I've had good words to say about Michael's Mufflers down here by me - Capitol and Pearl (down Pearl just a bit. It's across from Normandin.) That might be a bit of a drive for you.
For recommendations on systems, don't ask me. I like to hear my engine just a bit, so I know it's running! You could probably tell a shop what you want, and they could fix you up tho...
Sorry I can't suggest anyone closer...
Side Note - If you want to DIY, I've had good luck with the Walker Turbo II mufflers under my rigs. They're not loud, but they let you know your engine is actually running - and I find them rather mellow. And relatively inexpensive, and available locally...
Mufflers are for sucks!
Then again I don't have one and I always say "What?" after a long drive on the road. :gee:
Letterman said:
Mufflers are for sucks!...I always say "What?" after a long drive on the road. :gee:
IN TOYOTA PRIUS ?????
Not in your area, but worth the 40 min drive. Minute Muffler in Dublin, killer and clean installs, and Scott doe a lot of off road and custom jobs, very affordable.
Kwik-way muffler at Stevens Creek and Kiely across from Stevens Creek Toyota.
If I recall, that is a place I went to before for "special" jobs...
They always did a good job, and whenever I went back for a quick and easy weld, they would do it free.
I ended up going to El Camino Mufflers (not sure) at El Camino and Pomeroy on Thursday. They did a good job, no complains, very quick.
