throttle response/hi speed dog
going down the hiway,my gas pedal dont seem to do anything when i go past halfway to the floor.it will eventually kick down the trans a gear(auto)if i take off from a stop and get on it it is fine.my 2000 XJ runs good for the most part. i bought it a few months ago and slowly have been going thru it. it has new plugs and k&n drop in. the dealer tuned it ?when i had to take it in for stripped spark plug holes.supposedly the tps and 02 sensors are not bad according to the dealer. he told me when they tuned it after the plugs were changed that the machine would have showed a problem if a had one.THE QUESTION IS ,are these things (at highway speeds )just lame when you romp on it? also it was 96 degrees and i'm running 265/75/16(31.6") and stock speedo gear.
i could live with it..........if its normal.
thanx,mike
thanx,mike
