OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
High idle
Hi my 87 jeep cherokee is going into high idle again. it sometimes idles at 2000 rpms as opposed to 500. Is the tps the only thing that will correct this. I changed it last year and it helped a lot. it has just started up again this week, and i hope i don't have to replace it again. thanks
matt |
#2
oh yeah
its a 4 liter sorry
#3
Possible candidates:
1. Idle Air Solenoid- Clean it before considering replacement 2. Throttle body gunked from oil inhaled caused by a stopped up CCV tube. Clean the throttle body if it is black inside the bore. If it is black, remove CCV tube and clean and clean CCV gromet in valve cover. 3. Vaccum leak-trace out those plastic vac. lines |
#4
Do a search. You're not the only one.
#5
Cleaning the throttle body and the IAS eliminated my problem with high idle.
Thread Tools | |
Display Modes | |
High Idle - After Driving; Weird TPS... | LynchMob | OEM Tech Discussion | 5 | November 10th, 2003 16:41 |
High idle and emission maint light on HELP!?!?!?! | shag | OEM Tech Discussion | 3 | October 25th, 2003 21:22 |
High Idle still... | BenXJCA | OEM Tech Discussion | 20 | May 28th, 2003 02:28 |
Idle is high on 4.0l | 88justin | OEM Tech Discussion | 6 | April 14th, 2003 14:15 |
high idle problem | frsno jeeper | Sierra Chapter | 6 | January 12th, 2003 11:33 |
