Old April 14th, 2010, 19:38
smiley smiley is offline
error code 25
got any advice? engine check light came on and i got an error code 25. (actually 2.5) but i assume its 25. I did the key on-off-on-off-on-off thing and thats what came out? Do i need to replace my idle control motor or should I try to spray the sensor down with pb blaster to see if that helps.
FYI this came on after a short (1 mile) trip after the jeep was sitting for 2 weeks while i was working in TN.
Thanks you guys are great.
Smiley
2000 xj classic 31in tires 3 in lift (on for about a year with no problems)
flowmaster exhaust, kn fpik, 101596 miles (just in case you needed any of that info)
Old April 14th, 2010, 21:08
joe_peters joe_peters is offline
Re: error code 25
1. Key on off stopped working about mid-97.
2. Go to a parts store and have the code read, then post back here the exact code.
3. Don't replace parts based on a code, it is a diagnostic helper to point you in a certain direction.
Old April 15th, 2010, 06:50
Re: error code 25
so i got out there and looked and my tb was really gunked up. I am gonna clean it out before I do anything to see if that will keep the plate from sticking and fix the problem.... my question... does the check engine light go off automatically or do I need to reset it and if so how do i do that.
Again thanks for all the help guys.
I know you said error codes stopped in 97 but i got a code out, weather that's just a coincidence or it actually gave me and error code IDK
error code 171 danald OEM Tech Discussion 4 April 8th, 2007 16:52
Error Code 5 5 white96xj OEM Tech Discussion 2 April 13th, 2006 08:54
Error code GTIguy02 OEM Tech Discussion 3 October 29th, 2005 16:26
Error Code on 98 XJ LOOKSURF OEM Tech Discussion 3 March 8th, 2004 13:46
Error Code 34 - 96 XJ MarkF OEM Tech Discussion 1 December 9th, 2003 20:32
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
