Prev Previous Post   Next Post Next
Old September 30th, 2006, 13:17
twisted_ed's Avatar
twisted_ed twisted_ed is offline
High pitched whine from the engine at high idle, running speed
When my heep idles, there it sounds fine but as soon as you bump the idle up or go for a drive the noise starts at around 20 Kilometeres and hour and up. I have no idea what it could be, the belt seems fine... I am hoping its not somthing inside the engine, otherwise I am out of a vehicle for awhile.
I was thinking it could be like the power steering pump, belt idler, A/C, water pump (but its new so I doubt it), cooling fan, hopefully somthing easy to replace diagnose like that....
If I removed the belt and started it and reved it for a few seconds, that would elimiate all those components and the only downfall I see is no cooling pump.. but its only for a second, and at least it would tell me if its the engine or a belt driven accessorie.
Edit: I took off the belt and its not the engine, but an accessory so I checked them all. I think its my alternator, I spin the thing and it makes a squeal/whine. Im wondering what I can do, should I replace it now... or wait till it fails
got her running...now high idle tealcherokee Modified Tech Discussion 6 October 6th, 2009 10:22
high idle speed deesiexj OEM Tech Discussion 2 September 6th, 2006 20:18
High Idle after engine warm ExTankerGuy OEM Tech Discussion 4 January 6th, 2006 08:18
A high pitched whinning at McDonalds' drive-thru 4ESTJP OEM Tech Discussion 17 December 12th, 2004 11:35
High pitched whine/ whistle noise in engine area Orionseye OEM Tech Discussion 11 February 10th, 2004 07:18
