Old April 16th, 2005, 09:43
aduke aduke is offline
replacing fuel filter
ok im a little of a noobie..... i got a new fuel filter and to put it in i have to depresurize the system at the fuel rail. then just put it in.....right? its a 90' with 142,??? thanks in advance
Old April 16th, 2005, 09:45
PaulJ PaulJ is offline
Re: replacing fuel filter
That's all there is to it. Just pay attention to direction of flow for the filter.
Old April 16th, 2005, 09:47
Yucca-Man's Avatar
Yucca-Man Yucca-Man is offline
NAXJA Member # 683
Make sure you put it in facing the correct direction as well. A cap on the end of the old one as you remove it will help keep gas from pouring down your arm. Depressurize the fuel rail with a small (non-sparking preferred) screwdriver or dowel while holding a rag over the fitting to prevent drippage. Enjoy.
Old April 16th, 2005, 11:35
sweet.... i plan to some how run into a problem like i always do....but it only took about 10 mins. thanks a lot
Fuel Pump Relay Haywire? secutores OEM Tech Discussion 11 September 17th, 2009 00:31
2000 Fuel Filter jdraylob2002 OEM Tech Discussion 8 March 24th, 2005 15:00
Fuel Filter aplatz OEM Tech Discussion 14 September 27th, 2003 05:41
leaking fuel filter?! CaptTrev OEM Tech Discussion 6 September 10th, 2003 16:54
Gas Gauge one 1999 XJ Manuel OEM Tech Discussion 4 April 15th, 2003 16:15
