Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Grand Cherokee > WK and WK2 Grand Cherokees (2005 - Present)
WK and WK2 Grand Cherokees (2005 - Present) Technical forum focused on the new generation Grand Cherokees.
Old January 25th, 2020, 22:12
bjoehandley's Avatar
bjoehandley bjoehandley is offline
3.6l Plugs
Has anybody here bought a WK2 with the 3.6l Pentastar in it and had to replace the spark plugs yet?
It's time, if not past time to change the plugs in my 2012 200 with the 3.6l, but I'm curious to see who's used what for plugs in their Pentastars. Probably going to swap out to the MSD coil packs and the P.U.G. (Pentastar Up Grade) lower intake manifold with the plugs and a RPM Motorsports intake tube made for the 2011-2014 Avenger and 200 with this engine since the coil packs and upper intake half has to come off to get to the plugs anyway.
Old February 24th, 2022, 15:04
Ewenm's Avatar
Ewenm Ewenm is offline
Re: 3.6l Plugs
i guess you worked it out for your self, what were the results????
Spark Plugs 2000 XJ - Only find NGK Nickel plugs no copper. Mtb Jak OEM Tech Discussion 9 April 18th, 2014 17:15
freeze plugs/block plugs. Mitchen OEM Tech Discussion 2 January 23rd, 2011 10:21
Anyone know where these plugs go? dark92xj OEM Tech Discussion 6 August 20th, 2010 14:45
plugs POLmagnum OEM Tech Discussion 4 October 1st, 2009 08:22
Plugs.... plugs... plugs Kejtar Modified Tech Discussion 14 February 21st, 2004 11:54
