Old December 9th, 2003, 06:05
Cheropair's Avatar
Cheropair Cheropair is offline
MJ ride height? Am I sagging?
Measured from wheel center to edge of flare lip - front 18", rear 19".
Has about 170,000 miles on it, original as far as I can tell. Just seems to sit low compared to Cherokees running around here.
Any one else have an MJ, and what is the height? Is it different than an XJ, somewhere I heard that the MJ runs different flares front and back, would this account for a "taller than XJ" measure, yet still be shorter overall?
Old December 9th, 2003, 07:03
Jeff in VA's Avatar
Jeff in VA Jeff in VA is offline
<---respect
Re: MJ ride height? Am I sagging?
Mine sits at 17.5" both front and rear, stock short-bed, 2.5L. 155K miles.
HTH,
Jeff
Old December 9th, 2003, 08:45
Eagle's Avatar
Eagle Eagle is offline
Lifetime NAXJA Member
The MJ has larger rear wheel arches, so the rear measurement is different. Front is the same as Cherokees. I have measured a LOT of MJs trying to establish an average to use as "stock" height. So far, they average out to between 20" and 20-1/2" in the rear, so based on my measurements yours is down by an inch plus.
Eagle - Lifetime Member
Owner/Driver/Enabler of "The Fleet"
Self-appointed President-for-Life of the World MJ Preservation Society
Inboard lower control arms for lowered MJ? CheapXJ Jeep Street and Performance 5 December 9th, 2003 17:24
A chance at a MJ triple 4 Modified Tech Discussion 5 December 9th, 2003 03:58
MJ roll-pan? LT1XJ Modified Tech Discussion 7 December 8th, 2003 22:13
Sagging Springs yardape Modified Tech Discussion 1 July 31st, 2003 23:45
Stock Ride Height JimC OEM Tech Discussion 3 May 21st, 2003 17:14
