morelia1976
- Michigan
Need some help. I have a 97 XJ 4.0 AW4 that won’t start. It stalled once while driving a couple weeks ago, and I thought it was due to low gas. I put some gas in it, and then drove to my uncle’s to do some planned maintenance. We did the brakes, changed the front and rear diff oil, put on an aftermarket rear bumper, and it drove alright for a couple days, then started stalling again, while at idle and driving. After a few searches, I checked the battery and CPS, both bad, so replaced them and the TPS. Went for a short test drive and continued to stall.
Checked new CPS, bad, took it back and got a new one. Tested this one before installing it, cleared the codes, drove about 20m and it stalled again. Backed it up into my parking spot, turned off, and tried to see if there were any codes. Wouldn’t display any codes, even though I’ve never had problems getting 12 and 55 to display on my odometer and wouldn’t start. Let it sit for a little while and it started. Turned it off, checked for codes and got 12 and 55. Checked the CPS and read ~5V across B and C with my ohmmeter, so it’s bad. Again. That was Tuesday. Since then it won’t start, just keeps cranking, and won’t display any codes. I also found out the fuel pump keeps going as long as the key is on, it doesn’t cut off after a few seconds.
I figure it’s a ground fault causing my troubles, but I suck at electrical. Any help or guidance would be greatly appreciated. I also plan on checking fuel pressure, but am more worried about the wiring.
