- Westminster, SoCal
Ok, where the rear seal is on the shaft of the ax15 where it connects to the np231, it appears that the area between the ax15 and np231 is enclosed by an empty area??? in a casing type of a deal??? The reason I guess it's empty is because there seems to be a vent hole type hole about 1/2" below the level of the fill plug so if it was not full of empty air I'd be leaking something (btw transmission and the tcase are both topped off).....
My theory about the leak is now that the check valve on top might be stuck and when things heat up it pushes the oil out the rear seal into that area and then things leak out/fly out (due to air movemnt) out and make a mess..... Does it make sense????
Kejtar
Kejtar
