jeeptec
- atascadero california
i did the otk conversion.there are several dips in my nieghborhood. when the jeep compresses it goes to the right. uncompresses goes to the left.the steering wheel does not move. i have rechecked all the bolts and nuts. all tight. caster is 6.5. camber 1/2 neg. toe is set 1/16. diff is centered. tracbar and steering angles are in the same line. im running a ustys hd T style steering. which is simila to the other t style systems. i did shim the right tie rod to stop tie rod roll. over all it rides supper and steers real nice on smooth roads.
