Black1990jeep
- california
I got the front axle disconnect eliminator conversion my 1990 xj. The seal on the driverside for the axle at the diff is fine, it uses the stock seal. however on passenger side, the seal is not stock as the axle diameter is different than stock. the non stock seal on the passenger side are not as nice as the stock driverside seal. single lip seal verses double lip seal, plus the driver side seal has a cone shape to guide the axle into place during install
Well my passenger seal is leaking again, that seal is junkola.
what grease seal might be the best for this application? it is a big pain to replace, but by golly, I want a better seal. seeing as it is impossible to see the seal once the diff carrier is installed, it is not possible to know if the axle has folded over the lip of that seal or not. that is what happened last time, the seal got folded over despite care in inserting the axle ( never an issue with the stock driver seal with the two lips and guide cone )
any suggestions on what brand seal will work that might have a double lip and or a guide cone on it? This latest seal started leaking within a month, or at least it took a month for the diff oil to work its way out and drip on the ground.
thanks
thanks
