Old May 17th, 2018, 20:30
Black1990jeep Black1990jeep is offline
Adding a Drain Plug, Currie 9 in. Rear End
Id like to add a drain plug to my Currie 9 inch rear end. It has an Eaton TruTrac. I have no idea how it looks internally, the thickness of the case, where the lowest location is internally, nor how much clearance I have inside for a pipe tap to run up thru a hole I drill.
Would someone please provide how they have done this, or photographs on the inside so I can plan where to add the drain plug hole?
Thanks
Old May 18th, 2018, 00:12
RCP Phx RCP Phx is offline
Re: Adding a Drain Plug, Currie 9 in. Rear End
You will know where to drill when you pull the 3rd member. You may need to add a bung to make up for thickness.
Old May 18th, 2018, 06:30
VAhasnoWAVES VAhasnoWAVES is offline
youll need to pull the third out to clean the housing after drilling/tapping/welding (what ever method you chose). aside from the ring gear, youll have plenty of room to play. i added a giant fill/inspection to my 9 as well.
Old May 23rd, 2018, 13:24
XJEEPER's Avatar
XJEEPER XJEEPER is offline
NAXJA Member # 13
Thanks
2 minute Google search.......
Filler
https://ljrc1.com/item/1219552-175-a...-on?brand=9232
Drain plug location
http://www.jimmeyerracing.com/images...assis_019b.jpg
Drain plug
http://www.chassisunlimited.com/prod...rain-plug.html
Speak the Truth-Question with Boldness-Speak without fear.
Old May 23rd, 2018, 15:32
techno1154's Avatar
techno1154 techno1154 is online now
Originally Posted by XJEEPER View Post
The second drain plug option is the better option. I bought some from this company "www.bungking.com/steel-npt-bungs/"] www.bungking.com/steel-npt-bungs[/B]/ but am yet to use them.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old May 23rd, 2018, 17:58
I prefer a flush plug installation, but it's hard to accomplish! I recommend a 1/8-27 NPT for the most contact and zero exposed material!
Old May 24th, 2018, 07:35
1/8"? thats annoyingly small. my narrowed/shaved 9 took almost 5 quarts of gear oil. would have taken hours for it to drain through a 1/8" plug.
the better option for a drain plug is to shave it while you are in there... gain some ground clearance and give yourself a nice thick piece of metal to weld the bung to. mount it flush or sub flush. no photos of the plug, but it was 1/2" i think... big enough to get a weld on if you managed to beat it up and couldnt get an allen on it anymore. basically... miss the ring gear and youve got miles of room.
same goes for a fill/inspection plug:
Old May 24th, 2018, 07:39
side note.
just reread that your 9 is a currie unit... though that doesnt specifically imply that its a fab 9 housing. you have plenty of options either way.
Old May 24th, 2018, 10:01
1/8" NPT is about 3/8" in diameter!
Old May 24th, 2018, 15:49
techno1154's Avatar
That is easy to accomplish by drilling and tapping the housing and using an Allen head plug. Test fitting and tapping until the plug go in as far you wish assuming the housing material is 1/4" or thicker.
To protect the plug from being mangled, a piece of metal could be welded around the plug thick enough to extend below the plug. Look at the Toyota and Mitsubishi differential drain plugs for an example.
Patrick
#594
Oil pan drain plug deesiexj OEM Tech Discussion 5 August 18th, 2010 20:39
Cant get the drain plug out Trail Ready SoCal Chapter 23 April 29th, 2010 19:53
adding drain hole to Trans pan? dgrigorenko Modified Tech Discussion 14 October 18th, 2009 20:13
aw4 drain plug luvherinmyjeep32 OEM Tech Discussion 6 January 26th, 2007 17:44
Oil Drain Plug BCParker OEM Tech Discussion 30 December 16th, 2005 00:57
