Throttle
- A tree fort
Anyone else have this problem???
redneck23ms said:try putting the bolt in the other way. then gring down the head of the bolt a little until it clears.
Not without messing up the angles!xjtrailrider said:Would a drop pittman arm fix this?
JJacobs said:Your drag link is bent.
JJacobs said:Lift height doesn't have anything to do with it.
Throttle said:Anyone else have this problem???
xj_newb said:strange that this thread just popped up...
after having a similar problem (the TRE hitting my sway bar link, not my lower stabilizer mount), i decided to "flip" the TRE to the other side of the drag link. this all began after installing my RE 5.5" kit over easter.
well, turns out the TRE has a tapered stud - so how am i supposed to install backwards through a tapered hole? (i'm still not quite sure how this was done: http://www.delta4x4club.com/TECH/JEEP/re55lift/IMG_0365.JPG)
so, after crawling a few threads on the subject, i've decided to shift my lower control arms forward at my RE drop brackets. i'll let you know how it works out.
learning as i go,
xj_newb
