ok i will take advise, i need help again, the darn thing still leaks, it appears to be comeing from the bell housing, possibly the rear half of the oil pan, what is recommened lbs for the oil pan bolts, plus discovered a new problem today after a test drive the thing started overheating, so i checked the obvious place first i was going to check the thermostat, well i was takeing the second bolt off and the filler neck cracked well there is most of my problem and i was looking for the thermo and there was nothing there, so i figure someone else took it out, or so i thought after i had everthing off (ok here goes a doosy) the thermo had rusted and fell in the block i mean rusted over years and what i thought was the orange coolant turned out to be strait rust and the thermo bypass hose was completly cloged with crude, the previous owner has to be the most incompatant person that ever owned a car, well now i have bought all new hoses can filler neck and thermo along with some coolant(possibly the first this beast has seen in years) well another thing i noticed is the electric fan does not work so i had to hot wire it to a toggle switch, when i first bought this jeep i made a joke it will be completly new when i am thru with it looks like i was right.
