OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
red gasket maker ok with rubber pan gasket?
im doing the rms in the morning...i realized i bought the red instead of black, i have never used the red. will i be ok? or should i get the black?
thanks Sean |
#2
Re: red gasket maker ok with rubber pan gasket?
what does it say on the packaging?
you also need to add a dab of rtv at each end of the rms. how far from an autoparts store do you live where you cant just go and get another can/tube of gasket maker? |
#3
yeah doing the RMS is not the problem. i just wanted to know if red will be ok. it says oil pans, but not if its for cork or rubber.
#4
isnt gasket maker used by itself without a gasket or seal. i use a thin layer rtv on rubber gaskets.
#5
Only if your Jeep is Red, that would look tacky with any other color.
#6
I use red/white/blue on my junk so it's color cordinated......SANTA
#7
i just walked my lazy arse to the parts store and got black to be safe. now i gotta find a brass punch, seems its a hard tool to track down in my area.
#8
You might try a hobby store for the brass punch.
#9
If you go to a hobbie store or good hardware store just get a brass rod about 1/4" dia. +/- works great.....SANTA
#10
i hit every parts store around here, nothing. hobby stores are all 30 mins away, guess i might be takin a trip. im thinking Sears might carry them, im gonna call right now. thanks guys!
#11
It does not have to be a punch at all you will be just tapping on it anyway. With the brass rod you can cut it to any length you want and it works great.....SANTA
#12
thats a good point, thanks again.
#13
You can use aluminum - that's what came with my universal RMS kit in the '80's. And if you are using the rubber pan gasket, just dab the corners of the seal and front timing cover. The gasket can do all the rest.
Scraping off all the old paper gasket - that's the tough item. |
Thread Tools | |
Display Modes | |
Rear Main seal, 1 piece oil pan gasket and valve cover gasket | KingOfTheHill | OEM Tech Discussion | 28 | October 7th, 2008 23:39 |
gasket set | green95xj | OEM Tech Discussion | 4 | June 1st, 2008 09:51 |
Do I need both a thermostat gasket and thermostat housing gasket? | 90Pioneer | OEM Tech Discussion | 1 | March 5th, 2007 16:45 |
AX4 OEM Gasket: Cork or Rubber?? | XpedientJ | OEM Tech Discussion | 1 | September 27th, 2006 16:58 |
Using Permatex Aviation Grade Gasket Maker | BSD | OEM Tech Discussion | 2 | March 1st, 2006 18:41 |
