Old May 29th, 2006, 16:24
tealcherokee's Avatar
tealcherokee tealcherokee is offline
got her running...now high idle
well, it runs, and seems to be ok
temp gauge IMO still reads lower that it should, but tried a new sender and gauge, same results
now i have a wicked high idle 2000 rpm, until i unplug the TPS, then it drops back to normal
timing advance seems to be unadjustable, even turning the distributor, 5* at 700 rpm 13-15* at 2000
TPS is exactly 83% of input voltage at closed throttle
Old May 30th, 2006, 14:05
Re: got her running...now high idle
bump bump
Old May 31st, 2006, 11:30
MuddinJeeper's Avatar
MuddinJeeper MuddinJeeper is offline
Have you checked your air idle control??
Old May 31st, 2006, 12:06
well, i cleaned it, i also disconnect it, and it doesnt change anything
i still wanna know why it stops when i disconnect the TPS
Old May 31st, 2006, 13:18
RyanM's Avatar
RyanM RyanM is offline
Wonder what drdyno has to say, he probably hasnt seen it
Old May 31st, 2006, 13:35
hopefully he'll chime in
Old October 6th, 2009, 10:22
Harlee&Tahoe's Avatar
Harlee&Tahoe Harlee&Tahoe is offline
Originally Posted by tealcherokee
Its a little late, i haven't had the jeep for years,
in the end the RENIX wiring is the exact same color as the HO T.P.S.,
except they're backwards.
I don't remember the colors but it was something like purple, black, and orange on both but it
needed to be wired purple to orange, black to black, orange to purple.
Thanks for the response to the P.M. hopefully this will help future searchers.
I was also told I could use an automatic T.P.S. even though I have a Manual trans.
Any truth to this? Anyone?
This could save a fair amount of money as the manual T.P.S. is more expensive.
My NAPA would have to order (manual, RENIX) directly from manufacturer.
RUNNING HOT AT IDLE ebxjbob OEM Tech Discussion 5 April 6th, 2006 11:46
Very High Idle 88woody OEM Tech Discussion 3 April 3rd, 2004 11:36
high idle.. sidriptide OEM Tech Discussion 1 July 12th, 2003 21:25
High Idle still... BenXJCA OEM Tech Discussion 20 May 28th, 2003 02:28
High idle wardxj OEM Tech Discussion 4 May 22nd, 2003 08:01
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
