OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
Difference in body sides between early and late model???
I am trying to gauge whether or not the sideplates we just made will fit late model XJ's.
![]() Points of concern are whether or not the contouring of the panels is the same. Can anyone clarify? |
#2
Re: Difference in body sides between early and late model???
Those look SWEET!!!
Cant answer the question BUT...... if ya send me some black diamond plate ones I'll test 'em out on my '99 for ya. ![]() |
#3
yes , they are the same, you just won't need the rears. the door skins are the same panels.,just the bottoms of the quarter panels are different because of the bumper ends.
#4
#5
Great thanks!
I was 99% sure they were the same up to the fender well, then wasn't too sure on the back. On the 97+ is this piece plastic? ![]() If it is, you may be able to remove it and use the rear piece. |
#6
no, it's not the same under the bumper tip. you might be able to use your piece if it covers enough but it's different, not smooth like 96 & earlier. remember 97 up flares stop at the bumper tip.
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
A ? for the late model guys...... | hot_rod_hooligans | OEM Tech Discussion | 6 | May 20th, 2008 07:21 |
Have a late model OEM swing away? | smcdonaldaz | OEM Tech Discussion | 3 | May 19th, 2008 15:14 |
late model AC problems | whited | OEM Tech Discussion | 4 | October 4th, 2006 10:28 |
Late/Early model bumpers | karstic | OEM Tech Discussion | 3 | May 15th, 2005 12:48 |
Late Model XJ Body Parts | catyrpelius | Wanted: Private Party Only | 0 | December 12th, 2004 13:10 |
