Recently bought a 1999 Cherokee Sport arrived there it would not barely start and run determined it was getting no fuel did some research and filled the tank above 1/2 tank and it started. Noticed the fuel pump relay was burnt I think the pickup is clogged will get to that in a minute.
When the truck started had a hole in the tube that goes from the water pump to the heater hoses used some epoxy stuff to plug the damn and get the truck home. When I got the truck home I replaced the tube in the driveway when I was refilling the rad with water noticed it was dirty under the hood so gave it a good spraying down to clean it up.After that I was in a crank no spark situation I replaced the cps and am currently in the crank no start situation again.
I have checked all fuses, swapped asd relay , made sure the battery is fully charged and threw last nights chicken bones at it while chanting in what I figured was a pretty convincing curse removal chant.
I have checked the cps sensor and get the same readings on the old one and the new one A B C looks like C B A if you flip the sensor as I do not have the notch to place at the right as I have read it pretty much looks the same on either side. I have a reading of infinity on one side and 600 to 700 0hms on the other side.
I am going to go back where I bought the cps and exchange it tommorow I am just wondering if I am missing something more to check. As well is there a way to relably test the main computer as I am wondering if it is ok too now? Thanks for your time I swear I searched this and other forums before posting I am hoping I will get a unique perspective if possible.
