Old June 28th, 2008, 16:57
danny Benavidez's Avatar
danny Benavidez danny Benavidez is offline
PulStar Pulse Plug - spark plug
www.PulStar.com Pulse Plugs
Popular Science has been running the add in there magazine for some weeks.
Any one using this new pulse plugs ?
Old June 28th, 2008, 18:35
h2opete987's Avatar
h2opete987 h2opete987 is offline
Re: PulStar Pulse Plug - spark plug
seems snake oil to me. their claims about "wasted energy" from "heating ignition components" are misleading. I realize its their trade secret or whatnot, but a simple schematic (basic stuff, no values needed, even) would help verify their claims, but no such schematic exists.
I believe that you'd be better off spending the $150 ($25/ea) upgrading your coil/dist.
Old June 29th, 2008, 15:31
lawsoncl lawsoncl is offline
There is no way they are going to get 20,000 times the voltage without changing the plug gap. Looks like snake oil to me. I'm guessing they have a small cap inside the plug which might result in a slightly hotter but shorter duration spark. A better primary coil would be a better investment.
Old June 29th, 2008, 15:37
A real world test, showing no improvement and added emi noise. I question if he did a proper SAE dyno test, though. He didn't mentioned the runs were not done at the same engine operating temp, and didn't mention anything about correcting for intake air temp etc. It also sounded like he compared them to the set of existing plugs versus new stock plugs. But still, it certainly shoots down the claim of massive hp improvements.
http://www.allfordmustangs.com/forum...tar-plugs.html
Old June 29th, 2008, 16:49
Originally Posted by lawsoncl
Thank you for the report
Pulse plug and throttle body spacers both just sound good with no gain
Old June 29th, 2008, 17:30
igotanxj igotanxj is offline
They do have a much more powerful spark because they basically put a capacitor inside the spark plug to create a bigger spark. You guys ever heard of Nology hotwires? They have the same concept, a capacitor built into the wire with a ground strap hanging out to give the spark plug a much stronger spark. Its the same thing but inside the plug instead of the wire.
I have personally seen a demonstration of the difference between a normal msd spark plug wire on an msd system, and a nology hot wire and the difference is HUGE. It makes a BRIGHT LOUD pop for each spark. We put a sheet of paper in between the spark on both, and the regular msd system did nothing, the spark went right through it. But the paper going through the nology plugs caught on fire immediately.
Anyways, I've read a few articles on these spark plugs and they give like a 2% increase in power and torque production over the top standard type of plug. Its a great idea I think, I dont know about how long they will last in real world use though. Plus its a bit expensive for a set of plugs.
Personally I think they would actually work, and they seem like theyre on a different level than tb spacers, magnets, tornados, etc.
Pulstar Pulse Plugs falcon556 OEM Tech Discussion 4 March 23rd, 2008 13:12
Pulstar Pulse Plugs JNickel101 Modified Tech Discussion 5 August 19th, 2007 12:43
93 XJ Spark Plug Gap? Rynxprs OEM Tech Discussion 8 August 19th, 2006 18:45
Spark plug gap? homebrew OEM Tech Discussion 4 March 14th, 2006 18:07
Spark plug? TBLimited Modified Tech Discussion 1 February 15th, 2005 16:58
