Old April 5th, 2005, 10:39
gregclimbs gregclimbs is offline
rear d44 discs AND abs?
is there a rear d44 (for a xj d44 - YEAH - I just found one) disc conversion that allows the abs to still function?
tia,
g
Old April 6th, 2005, 18:16
falcon556's Avatar
falcon556 falcon556 is offline
I have not Confirmed, or I used a BAD email Addy
Re: rear d44 discs AND abs?
tia,
g
I did it on a D35, you need the tone rings and sensors. The tone rings are steel therefore they can be machined to the proper diameter. If you use the original tone rings you might be able to use the original sensors.
Here is a link to a conversion using a ZJ disc system.
http://www.members.cox.net/nraok2/
