Old May 12th, 2018, 03:57
Vince's Avatar
Vince Vince is offline
Replacement oxygen sensor connectors
I would like to replace the factory wiring harness connector for the oxygen sensor on my 1993 4.0L . I found this useful site for replacement connector info but it only goes back to 1997 models.
http://connectors.dcctools.com
Does anyone know what the part number is for a wiring repair kit for the downpipe oxygen sensor on my '93?
The replacement sensor is a Bosch 15704
https://www.rockauto.com/en/moreinfo...=279834&jsn=12
Old May 13th, 2018, 11:40
Vince's Avatar
Re: Replacement oxygen sensor connectors
I haven't found what I am looking for yet, but this store may be useful to someone.
http://www.repairconnector.com/
Old May 13th, 2018, 13:24
90XJ_Seth 90XJ_Seth is offline
This may be what you're looking for. It is a standard connector for your O2 sensor I believe and comes with all the repair pins but you will need to solder.
https://www.amazon.com/Delphi-Circuits-Weatherpack-Waterproof-Terminal/dp/B078Q3K83Y/ref=sr_1_1?s=automotive&ie=UTF8&qid=1526242987&sr= 1-1&keywords=4+pin+square+weatherpack
Old May 16th, 2018, 12:55
Vince's Avatar
Perfect!
Thank you very much.
98 xj oxygen sensor its an xj thing OEM Tech Discussion 5 March 30th, 2011 09:46
Oxygen Sensor Replacement $$ jeepngirl25 OEM Tech Discussion 47 September 27th, 2009 18:15
Need Help with oxygen sensor mbogosia OEM Tech Discussion 5 December 4th, 2008 04:58
Oxygen sensor replacement: what type? Headache OEM Tech Discussion 7 March 26th, 2004 06:41
Oxygen Sensor 97XJ OEM Tech Discussion 2 June 10th, 2003 09:55
