Old April 13th, 2018, 12:54
denverd1's Avatar
denverd1 denverd1 is offline
beadlocks: weld-on vs $$$
Picked up a set of waggy 44s. Then picked up a set of 37s. was going to wait until fall/winter to start working on them but now that I've got a good sized parts pile, I'm getting antsy to get them torn down, regeared, trussed, locked and under the jeep.
Still got a few things I need to get sorted out before I get cracking on it, but started looking at beadlocks. Thought I would weld a set of rings onto a 17" steel wheel. 17x9 wheels are around 90'ish plus another 100 per wheel give or take for the rings and hardware. Or pay 350'ish per wheel for Trail Ready or similar beadlocks.
Any downside to weld on beadlocks? I do know the weld has to be good and sit flush with the lip of the wheel and obviously hold air. Other than that, is there any difference in building a set vs buying them? The beadlock rims (Trail Ready)these tires came off of left the tires in perfect shape, bead not deformed at all. That's how I want these to work as well.
what's your experience with weld ons? or should I pony up for good rims?
Chili Pepper '98
4.5" lift, locked on both ends, 33s
10K winch and a lot of skinny pedal
Old April 13th, 2018, 13:09
RCP Phx RCP Phx is offline
Re: beadlocks: weld-on vs $$$
You would get out of it, what you put into it! What all equipment do have to do the job?
Old April 13th, 2018, 13:15
denverd1's Avatar
110 flux core welder. actively looking for a hobart 140 so I can use gas. done a few projects with it but probably wouldn't use it for welding on rings, or I could go to a buddies shop for a bigger unit.
Chili Pepper '98
Old April 13th, 2018, 13:37
Well that's not going to work! How would you cut the wheel straight/true?
Old April 13th, 2018, 14:02
denverd1's Avatar
cut the wheel? Guess I'll watch some vids. didn't think cutting a wheel was part of process and never seen it mentioned in any DIY beadlock writeups. thought the inner ring dropped inside the outer lip of the wheel
Chili Pepper '98
Old April 13th, 2018, 14:15
That only works for "beadlooks" !!!
Old April 13th, 2018, 14:22
two_door_rob two_door_rob is offline
I've got DIY beadlocks from Total Metal Innovations. You drop the inner ring in and go to town with the welder, no cutting involved.
Old April 20th, 2018, 08:33
burntkat burntkat is offline
NAXJA Member #1145
Looks like you've not looked into this in a while. There are locks out there that drop into the front lip of the wheel and weld in.
A 120VAC wire-feed welder is plenty to do this, so long as it will handle the material. I used fluxcore with my Lincoln 3200HD and it worked a treat.
Honestly, I am pretty sure you could do it with a 120VAC inverter stick box. I may try that, as I have a set of wheels to build.
BTW, they don't cost $100 each, either. TMI's product (the best I have found in this product) are $50 each. Put them on a steel wheel, brand new, you're looking at $100/wheel, complete assembly. Less if you use old wheels (I am using old "trash" wheels that had a bit of rust).
I wouldn't use the diybeadlocks.com product if you made me, not due to the product itself (though it IS inferior!) but due to the way the owner comports himself. Complete asshat.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old April 13th, 2018, 13:40
sandfreestyle sandfreestyle is offline
Time is another aspect. Is the time it takes to makes the mod (assuming you don't mess up) worth the gamble? Now if you mess up, you're right in the ballpark of just buying a set from the start.
Old April 13th, 2018, 13:53
Check these out!
https://www.youtube.com/watch?v=G3JBc5R5aJw
https://www.youtube.com/watch?v=io-hWLeIiHY
Old April 13th, 2018, 14:37
srb531 srb531 is offline
or just go w/ some allied rock a thons, reason cost,good quality steel beadlocks, summit racing has the best prices on them & quick delivery. why bash up $350 a wheel alloy wheels when you can bash up much cheaper steel ones. and they both do the same job. i have used them on 2 jeeps so far , never popped a bead yet , even w/ 37's at 8 lbs. have even went as low as 4 lbs sometimes for serious rock crawlin. i just cant justify $350 a wheel .
Old April 13th, 2018, 14:55
Sorry, my mistake I hadn't looked into it for years, there are a lot a new kits out there! I'm old and old schooled!
Old April 13th, 2018, 15:03
denverd1's Avatar
wondered what was going on!!
Chili Pepper '98
Old April 13th, 2018, 15:24
denverd1's Avatar
got a link? summit has double beadlocks and a couple rings
found an article on rockcrawler.com, but the banner ad for them was dead
raceline buy allied or something?
very interested in allied, just can't find them. well, I found these: https://www.alliedwheel.com/p-1526-r...beadlocks.aspx
but we're back to $300+ for 17x9
Chili Pepper '98
Old April 13th, 2018, 17:36
fourxdoctor.com has 17 x 9.5 allied wheel bead locks for $217.00 , depending on the lug pattern you need , 17 x 8 is even less cost.
Coyote internal beadlocks or weld on beadlocks? Hdcor4whlr Modified Tech Discussion 5 August 30th, 2017 17:52
Weld on Beadlocks, from who?? R.DesJardin NorthWest Chapter 3 February 17th, 2017 18:31
4 15x10's and 5 weld on beadlocks Micah For Sale: Private Party Only. XJ ITEMS ONLY 2 August 17th, 2007 18:47
weld-on beadlocks xj4life Modified Tech Discussion 5 December 20th, 2006 16:41
Weld on beadlocks and hot girls kissing each other Fore Wheeler Modified Tech Discussion 39 October 18th, 2003 08:54
