blazinjames
- Vancouver BC, Canada
I have a 1995 XJ I just finished installing a basic lift in. I have leafs spring with add-a-leaf and shackles. Im guessing its about 4in and in the front I have 3 in coils. I also have an adjustable track bar installed. Im will be adding a coil spacer to even it out.
Since lifting the jeep I have noticed my steering seems very loose and the car drifts to the right a bit.
I have a set of adjustable rubicon express upper and lower control arms to be installed.
to address the steering I will be going the Inverted T/Chevy 1 ton TRE route and probably ream the steering knuckles to go over axle.
should I make sure the control arms are installed and my proper caster, pinion alignment and toe in are all set before I upgrade the steering?
Thanks
Thanks
