SARgroundpounder
- San Jose, CA
I need rotor/brake help. Are there two different style rotors for the non-disconnect D30?
I just swapped my disconnect D30 out of my '89 XJ with a HP non-disconnect D30.
The "new" axle didn't have brakes and I thought I could just swap the brakes from my current set-up. The inner diameter of the '89 rotors was too small to fit over the newer axle's hubs. I just did a search on the forum and now know that the brakes are different.
Here's my problem: I just bought new Raybestos rotors for the '95 D30 and discovered the offset is too much. The inner side rotor rubs against the dust shield. :hang:
What's the easiest way to fix this?
