Old October 19th, 2004, 17:37
XJ618 XJ618 is offline
Fabrication
ok i am completely new at fabrication, im talking no idea, i think its pretty nuts though and the search just isnt specific enough. so help me out. i know people use metal that is 3/8"? i think, for a good durability/weight ratio, and i know everything is welded together. my question is what do you use for the actual face of say a bumper? im guessing some sort of thick steel sheet, but what do you use to bend it, or do you cut the specific peices and weld all 90* angles?? does anyone have any plans (like from acad) they could post just to see how you would draw up something like this? I know a lot of you are really into ths so i would appreciate any advice or words of wisdom i can get. thanks
Old October 19th, 2004, 17:44
Redcbr007's Avatar
Redcbr007 Redcbr007 is offline
Re: Fabrication
most people use 3/16 - 1/4
i only use 3/8 for key items that need a whole lot of strength....ie: wristed arms
Old October 19th, 2004, 17:45
TrailHunter's Avatar
TrailHunter TrailHunter is offline
NAXJA Member #1309
Re: Fabrication
3/8" steel would be extremely heavy for a bumper. 1/4" would be indestructable still and 50% lighter. I like to use 1/4" where I might actually hit the bumper on a ruglar basis and then just somthing lighter like 3/16" for the rest of the bumper. I personally don't want 100 lbs of steel hanging off the end of my XJ. It's always a balance. Many bumpers out there like TrailReady's bumper only uses 1/8" and they say it's "bullet proof". I wouldn't go any lighter than 3/16 and 1/4 being truely bullet proof.
Old October 19th, 2004, 18:59
RCP Phx RCP Phx is offline
Re: Fabrication
Strength comes from form more than material thickness!Mines got everything from .120" wall to 3/8".It took a week to form fit the radius of the front grill!
Front Bumper Pics
Old October 19th, 2004, 19:02
BrettM's Avatar
BrettM BrettM is offline
Re: Fabrication
box tubing and angle are your friends to avoid too much welding
Old October 19th, 2004, 20:01
Beezil Beezil is offline
Member #Nay
Re: Fabrication
it would only be 33% lighter.
I suggest 1/4" for the frame tabs, 1/4 or 3/16 for the winch box, and 8 ga. for the "skin"
geometry will determine what material thickness is needed.
a .120 strip of steel, bent in a hat section is more rigid than an unformed strip of .250 with the same outer dimensions.
Old October 19th, 2004, 20:10
OT's Avatar
OT OT is offline
Re: Fabrication
33.3333333% lighter
Old October 19th, 2004, 20:11
C-ROK C-ROK is offline
Re: Fabrication
But 3/8" is 50% heavier than 1/4"?
How can 1/4" only be 33% lighter than 3/8"?
Is this non-linear math?
kidding....., ok?
I agree with Beez, mostly. My old bumper was .125" skin over 1/8" square tube with a 1/4" wall angle at the lower "leading" edge. It held up to everything but a failed attempt at a 5200lb backflip.
Old October 19th, 2004, 20:12
Member #Nay
Re: Fabrication
Originally Posted by Okie Terry
33.3333333% lighter
thanks.
which one of you guys thought it was important to clarify?
Old October 19th, 2004, 20:51
Lincoln Lincoln is offline
NAXJA Member #321
Re: Fabrication
thanks.
The dude in the middle? He looks more like a claifier.
Old October 20th, 2004, 05:48
Re: Fabrication
Ya. That's me in the glasses.
Damn them cool lellow tinted shades.
Chicks in the chess club dug those.
Old October 20th, 2004, 07:43
Lawn Cher''s Avatar
Lawn Cher' Lawn Cher' is offline
Re: Fabrication
You should go find a local steel supplier and see if you can wander around in their warehouse, getting an idea of the various shapes and thicknesses available. Nothing like firsthand visual aids to clear up your questions.
Old October 20th, 2004, 17:20
NAXJA Member #321
Re: Fabrication
Think whatever makes you feel good.
Old October 20th, 2004, 18:00
OT's Avatar
OT OT is offline
Re: Fabrication
Well, you know a thread has served it's usefulness when Linc posts on it.
Stick a fork in this, it's done.
Old October 20th, 2004, 20:10
NAXJA Member #321
Re: Fabrication
I've posted on it several times.
First real fabrication project: long arms mission-inc Modified Tech Discussion 18 September 30th, 2004 08:26
TrackBar fabrication supernatural Modified Tech Discussion 8 August 4th, 2004 08:53
transfer case linkage fabrication ideas,.. bxj Modified Tech Discussion 7 June 22nd, 2004 09:14
wanted: fabrication tools & advice staticrevolution Wanted: Private Party Only 2 March 9th, 2004 21:08
Cage fabrication Uni Modified Tech Discussion 1 July 23rd, 2003 11:29
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
