Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Colorado Chapter
Colorado Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Old July 3rd, 2011, 16:31
DJManche's Avatar
DJManche DJManche is offline
When it rains .....
First off thank you Troy for saving my ass , just when you think your down ,
another pop in the gut .
Just when I saw the silver lining at the end of the day and Troy rolls off in my last project truck I focus my attention on my 92 , finishing the serpentine belt
and getting it ready for the road , I crank the 92 MJ up to head out and the throttle sticks and sends the motor high almost throwing a rod , so needless to say my last Jeep is done .
I may sell it if I have a buyer ...
Old July 3rd, 2011, 16:50
DutchVDub's Avatar
DutchVDub DutchVDub is offline
Re: When it rains .....
So did it bugger the motor or ddid you manage to save it?
Old July 3rd, 2011, 17:12
DJManche's Avatar
No its shot , barely runs .
Old July 3rd, 2011, 17:20
eflores eflores is offline
Sheesh what's wrong with it exactly?
Old July 3rd, 2011, 17:37
DJManche's Avatar
Almost threw a rod out the block . Barley limped it home but you can't step on the gas without allot of vibration .
Old July 3rd, 2011, 17:49
JJacobs JJacobs is offline
How do you almost throw a rod? It does or it doesn't.
How's the compression?
Old July 3rd, 2011, 17:55
DJManche's Avatar
I have not had time to check it but its bad , real bad . Barely idles .
Old July 3rd, 2011, 18:02
Hypoid's Avatar
Hypoid Hypoid is offline
and check the valvetrain. I've pumped lifters, had lifters stuck in the bore from over-revving. It barely ran until I put some ATF in the oil.
Think positive, sort out the problem before you stick a fork in it.
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old July 3rd, 2011, 18:15
DJManche's Avatar
I'll have to tow it , I don't have time to fix it .
Old July 3rd, 2011, 18:21
puttzer's Avatar
puttzer puttzer is offline
NAXJA Member #3000
How much????
98 XJ 4.0 AW4 231
Old July 3rd, 2011, 18:32
DJManche's Avatar
Probably 3k , I don't know . I might just need a place to store it .
Old July 3rd, 2011, 18:47
DutchVDub's Avatar
Sounds likes valve train issue to me, but I would definitely check it out before giving up on it.
Old July 3rd, 2011, 19:03
YELLAHEEP's Avatar
YELLAHEEP YELLAHEEP is offline
Yeah, if it ain't knocking...... the bottom end is likely fine. I suppose with a super high rev you could have stretched or floated the timing chain and skipped a tooth or two which would make it run like that.
I sure hope you don't have to bail on your '92. That'd truely be a shame.
Old July 3rd, 2011, 19:33
Frank Z Frank Z is offline
Wanna borrow my compression tester?
Old July 3rd, 2011, 19:48
DJManche's Avatar
I don't want to give up on that truck but an economical solution might be a better switch considering my predicament .
I'm sure its either valve train or slack in timing causing the idling and rough , either of witch
I'll need time and help with that .
Rate This Thread:
Bumpsteer/Loose Steering Only When It Rains Cherokeekid88 Modified Tech Discussion 1 September 23rd, 2009 08:45
When it rains, it pours!!! ColoradoRaptor Colorado Chapter 19 October 17th, 2008 20:08
Did a search, Tach doesn't work when it rains. BAs96XJ OEM Tech Discussion 4 April 24th, 2005 09:57
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
