Old January 22nd, 2011, 17:15
Mitchen's Avatar
Mitchen Mitchen is offline
freeze plugs/block plugs.
do i need to use any kind of sealant when i install these? i was told to use the gasket maker stuff in the tube.. this didnt sound right or like a good idea to me.
figured sealant could cause problems in the system..
first time replacing plugs.
Old January 22nd, 2011, 19:27
seigeXJ90's Avatar
seigeXJ90 seigeXJ90 is offline
I just replaced mine.. I used permatex #3 around the edges... stuck them in (the permatex held them in place) then lightly tapped the center with a hammer just to seat them a little then tapped around the edges till they were seated flush... no dents or dings and all are in perfectly
Sent from my HTC Evo using Tapatalk.
Old January 23rd, 2011, 11:21
joe_peters joe_peters is offline
Re: freeze plugs/block plugs.
Agree.
GoJeep's article: http://go.jeep-xj.info/HowtoWelshPlugs1.htm
Freeze Plugs SCupstateXJ OEM Tech Discussion 13 August 8th, 2007 22:02
Freeze Plugs s7tech OEM Tech Discussion 4 July 4th, 2007 11:00
Freeze Plugs jblaze5779 OEM Tech Discussion 2 July 28th, 2005 07:13
Freeze Plugs BIGPUNthug OEM Tech Discussion 3 February 14th, 2005 15:27
Freeze Plugs Revisited... GSequoia OEM Tech Discussion 7 November 7th, 2003 12:11
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
