Old February 16th, 2008, 22:14
moparjim1987's Avatar
moparjim1987 moparjim1987 is offline
Ughhhhh!!! Now i'm pulling my hair out.....
Ok...now i've posted a couple of times before about my cherokee's crappy running situation. I'll give you a rundown on what i have done so far: when i got it, i cleaned the throttle plate and ran seafoam through the intake system. then i replaced the tps, cts, cps, and the evap purge solenoid. then today, i checked the fuel pressure and it held steady as a rock, @ 45-50 lbs. So basically what my problem is, is i will take the truck for a drive, then shut it off, wait for about 10-20 mins, then when i go to start it, after about 1 minute of running it starts stumbling and idiling really low, like 350-400 rpms. then i can goose the throttle and it clears up and runs fine. then when you go to drive, it runs out first gear fine then when it hits second, it acts like you cut the fuel pressure in half and it stumbles again but if you let off the gas, it runs fine and then it never does it until you shut the truck off. i appriciate any and all help on this matter.
Old February 16th, 2008, 22:17
Shorty Shorty is offline
Gone but not forgotten...
Re: Ughhhhh!!! Now i'm pulling my hair out.....
any more info? like what year, engine, trans, mods.. etc
Old February 16th, 2008, 22:59
ColoradoRaptor's Avatar
ColoradoRaptor ColoradoRaptor is offline
Headbanging Hillbilly
X2
People crushed by law, have no hopes but from power. If laws are their enemies, they will be enemies to laws; and those who have much to hope and nothing to lose, will always be dangerous. Edmund Burke
Old February 17th, 2008, 06:00
birchlakeXJ's Avatar
birchlakeXJ birchlakeXJ is offline
And how many miles on your engine??
Looks like you've replaced a lot of sensors but how about tuneup basics?
Plugs, wires, distributor cap and rotor (unless yours is an 00/01), air filter.
You don't have the classic symptoms, but can't rule out fuel injectors either......
Old February 17th, 2008, 16:49
Oh yea i thought about that after i posted that last nite...it is a 1997 cherokee sport with a 4.0, aw4, dana 30 and 8 1/4, and a homemade air intake and not much else. and there looked to have been a tune done on it not too long before i bought it, but i'm seriously concidering doing it myself to install some performance goodies on it for more power and torque.
Old February 17th, 2008, 20:16
HotwiredXJ's Avatar
HotwiredXJ HotwiredXJ is offline
When you say home made air intake, that makes me wonder. All crank case vent lines hooked up? Sounds like it is starving for air at idle. Just my 2 cents
Old February 17th, 2008, 22:23
RichP's Avatar
RichP RichP is offline
Interesting, my 98 was doing something similar but not as bad. I'd been living with it since the jasper engine went in last year. Seemed like a dead spot in the TPS to me but it never died, just lost it's nads every once in a while. Fast forward to two weeks ago, alternator went out, replaced the alternator and reconnected the battery, that was after it sat overnite waiting for the alternator. Fired it back up later the next day, went thru the 'ran like crap' for the first half hour and then it relearned. Since then it has not done it. I don't know whether it relearned wrong the first time when the new engine went in and ran like crap or if it was the alternator going bad for the past 11 months. Between the jasper engine going in and the alternator going bad the battery had never been disconnected. Disconnect the battery and let it sit for a couple of hours and then reconnect it, see what happens.
Old February 17th, 2008, 22:47
WB9YZU WB9YZU is offline
I recomend fixing your problem first before you "install some performance goodies on it for more power and torque".
Relearning the computer is a good idea.
So is checking cap/rotor/plugs.
Check ground staps from engine to frame/firewall.
How are the battery connections?
Is it flashing the Check engine light.
Have you checked to see if it is throwing any diagnostic codes?
Sometimes the PCM will throw a code, but not light the check engine light. It would be interesting to know what the PCM thinks is going on. Get a cheap reader.
Something which happened to me:
I had a bad O2#2 sensor (smashed it against the floor) and it popped the O2 heater fuse. The rig would run a bit rich at first (burp it and it would be fine again), until the engine temp reached the switchover spot from Open Loop to Closed Loop, then it would want to die until the O2 sensor got warm enough to get the mixture right. It wouldn't always light the CEL, but would always throw a code because the heater is supervised. So checking the codes is something you may want to start with instead of throwing parts at it.
Good Luck!
HELLLLLLLP!!! Stumble at idle. Pulling my hair out!!! RANSOM OEM Tech Discussion 6 October 14th, 2007 07:08
I'm Losing My Hair!! Yucca-Man Colorado Chapter 15 March 25th, 2007 12:15
Goodbye Hair Ramsey Non-Tech / Off Topic 106 October 27th, 2006 14:01
Tesla...The car...not the hair band! Gil BullyKatz Non-Tech / Off Topic 19 October 1st, 2006 07:44
Opie? When did you cut your hair? DrMoab Non-Tech / Off Topic 17 July 11th, 2006 11:48
