Old June 20th, 2018, 14:23
Rockwood Rockwood is offline
Re: Power Steering Upgrade Ideas
Stock pump and remanufactured box store box with 33x12.50s on beadlocks (10-ish psi on some trails) and lunchbox lockers F/R (read: always on). Steering sucked about 40 minutes into a run. Added a 5 row cooler on the low pressure side and good synthetic fluid, steering will slide the whole front of the Jeep away from a rock all day long. Another thing that helps a lot is to stay off the steering stops. You're not turning any harder, just making heat.
Old June 20th, 2018, 16:31
sinat01's Avatar
sinat01 sinat01 is offline
a steering cooler helped mine out a lot. im on 33x10.50R15s tho so less tire to turn
No power steering at idle after Durango box upgrade Jays siik xj Modified Tech Discussion 30 June 23rd, 2014 15:48
want to upgrade my power steering pump on my 99 xj mopar98rt Modified Tech Discussion 5 November 10th, 2010 11:01
Power steering upgrade fireLt. Colorado Chapter 1 December 7th, 2009 20:35
Upgrade a Power Steering Pump Murphster05 Modified Tech Discussion 5 March 14th, 2009 16:11
Upgrade power steering pump? ZachMan Modified Tech Discussion 15 February 5th, 2006 13:55
