Old November 22nd, 2020, 09:28
Black1990jeep Black1990jeep is offline
Throttle Position Switch Adjust
Adjusted the T.P.S. last night. Target output voltage is 17% of input voltage. Mine was set at 14% which gave me a high idle and poor throttle response. Set to 17% and boy howdy, things are much better now.
of course there was an issue, hex head screws where found holding the TPS, the lower one was loose, and could not be tightened with other than an open end wrench, for which there is no room to swing the wrench. These should be Torx head screws. Hardware store had some Allen cap screws that fit fine, I can easily fit an Allen wrench on them for correct tightening
So now all is well. and I lived happily forever..... Well maybe........
Old November 22nd, 2020, 15:11
Saudade's Avatar
Saudade Saudade is offline
Re: Throttle Position Switch Adjust
I've had issues with mine. Steel screw and aluminum housing, not a good match.
I stripped the lower one out and found a phillips with matching threads, just too long. Chased the threads with a bottoming tap, added a small flat washer, trimmed length (a bit longer than original) and used anti-seize.
Hope I never have to adjust again.
1988 Laredo 2wd Auto, AKA "Grey Ghost", 206K
Tips for adjust of crank position sensor jovian OEM Tech Discussion 12 May 2nd, 2013 13:11
to adjust brake switch. wim hoppenbrouwers OEM Tech Discussion 2 September 11th, 2009 00:44
Throttle Position Cal. Need Help! PuddinHead OEM Tech Discussion 2 July 24th, 2008 21:19
Throttle Valve adjust landscaper South East Chapter 1 July 15th, 2007 20:11
Wet TPS/Throttle Position Sensor... 5-90 OEM Tech Discussion 2 April 25th, 2006 22:26
