skinnyfat_ms10
- so cal
Has anyone upgraded their cooling system with the ford electric fan set up if so i would like some insight
A '94-'04 Ford Mustang two-speed electric fan would also work and is equally as good as the Taurus fan.
I believe it is the same fan. Ford has a habit of cross platform part sharing...
I have one.
My installation was not typical or easy at all though.
As you can see I relocated my Radiator forward about 2 inches. I relocated my Transmission cooler To below the radiator and it fills the void in the Taurus fan shroud perfectly. This photo was a few years ago when I first made the mod, I've since cleaned up the wiring.
Best part is that the Ford fan will set inside of the Jeep Mechanical fan shroud which makes mounting it easy. I did my entire installation in a morning.
QUOTE]
Do you have any pics of that? I want to install my Taurus fan while I install my stroker,I do agrre with trimming it would fit but was waiting on someone here to figure it out!...THANKS!
Slightly OT, but what pump are you running and how much was it? I thought about this.I believe it is the same fan. Ford has a habit of cross platform part sharing...
I run one. I have it wired so that it runs on low speed with the ignition on and shifts to high when the controller calls for fan. I also have my Factory aux Fan wired in parallel to the Ford so that it comes on by command of the controller whilst preserving the ability of the PCM to call for Aux Fan during AC operation.
I am using my water pump controller for the Ford fan as I run an electric water pump as well. I do recommend some sort of Fan Controller be used. The good ones are PWM (Pulse Width Modulated) and have to ability to run the fan at any speed not just low/high.
There are a couple of very good threads here that detail the how to aspects.
Has anyone added an electric fan w/o serious mods like moving the rad or hacking off the clutch fan pulley?
