Connector near C101
DZRTANK
Chino Valley, AZ
Hi guys. I completed eliminating the C101 connector today. Within the same bunch of wires was a grey connector with 5 wires. 2 are black and the other 3 are different colors. The 3 colored wires are wrapped in a foil of some type. I think it is the C116 connector, or (EEC TO INJECTOR)
My questions.
What is this connector for?
Should I eliminate it before I put the split loop back on the harness.
Why is it wrapped in foil?
If some foil is missing, should I add some new foil?
Can I use aluminum foil or is it special?
Thanks
Clay
Most likely it's not just "shielded" wire but also a "twisted-pair"
What about the shield that has come loose? Should I purchase shield tape from Amazon and add to it, or is it not that important and just put some split loom around it and call it a day.
It's really not significant if it's only a short distance and the shield is intact in the middle.
