xj_dummy
- reedley, ca.
I have a 2.5L with a ax5 5 speed transmission.
My Clutch master cylinder was leaking on the inside of the cab, so I wanted to replace it before it would fry the fuse block directly below it.
So I replaced it with a new one and according to the Haynes repair manual about bleeding the clutch, I had to remove the "external clutch slave unit" and insert a socket to depress the piston then bleed it like a brake setup.
I did all that and when I installed it back into the tranny, the clutch pedal wouldn't move at all. A friend says that I have hydro lock but I turned the bleed screw and the pedal moves. But when I tighten the bleed screw it didnt fix anything.
So Where does the clutch slave cylinder plunger shaft move in the transmission?
Does anyone have an exploded view of that transmission showing where the slave sits?
Has anyone else had a problem like this?
Thanks for anyhelp.
Thanks for anyhelp.
