Strange deal here. My turn signals do not work unless I pull the hazard switch then they work normal and when doing this the hazard lights dont work. The hazard lights dont work at all. Any way I got to poking around and found that both blinker modules work fine but that the hazard fuse under the hood was blown. I put a new one in and the hazards work but it also turns on the brake lights. However, the brake lights do not work at the pedal. So in a nutshell, I have no brake lights, turn signals or hazards but the signal work when the hazard switch is pulled.
