2001XJ
- Canton, MI
Guys,
I installed the RE 4.5 lift on my XJ. I got the front completely done. I have upper fixed control arms and lower adjustable ones. I have a problem with the passenger side coil spring....it is bowing a little toward the front. I have rotated it 180 degrees, made sure it is completely set in the spring perch bucket, and even double checked the control arms. I can't figure why the driver side spring is completely straight while the passenger side is bowing a little. It is almost like the passenger side of the axle needs to be moved forward a bit but the upper control arms are fixed so they wouldn't allow much slop as it is (even if i could move them, they should be the right length anyhow) also, the axle is already centered inside the wheelwell so if I move it forward at all it won't line up right. ANY SUGGESTIONS!!!
2001XJ
2001XJ
