Old March 21st, 2008, 23:32
mramr1974's Avatar
mramr1974 mramr1974 is offline
Question help oring filter adapter , still leaks after instaling new orings?
well i need some advice. I have just put new orings on the adapter for the oil filter twice today and it still leaks. the second time i took it back off
i made sure it lined up good and even used some orange rtv but it still leaks so im baffeled if anyone has done this recently or has any bright ideas please let me know thank 91 xj 4.0 h0.
Old March 22nd, 2008, 03:51
91XJRubicXD's Avatar
91XJRubicXD 91XJRubicXD is offline
Re: help oring filter adapter , still leaks after instaling new orings?
Sounds to me like you have the wrong filter. If you look on the firewall on the passenger side of the truck, there may be a sticker regarding the upgrade of the oil filter threads. I have a 91 Cherokee and I have this in mine. Wrong threads even though it may screw down can easily cause the leaking. I'll give you a pic of the sticker I am referring of :
Old March 22nd, 2008, 05:59
90Blue_XJ's Avatar
90Blue_XJ 90Blue_XJ is offline
I don't think he's talking about the filter leaking but the adapter that bolts up to the block where the filter screws on to. The above diagram only details the oil filter onto that adapter.
Check that the complete old O-ring is out of the groove on both surfaces of the adapter. A small piece of the old ring still in there will keep it from sealing tightly.
Old March 22nd, 2008, 06:40
icewolf73's Avatar
icewolf73 icewolf73 is offline
I just changed the o-rings in my '91. All I can tell you is make sure you have the correct ones (a Jeep dealer gave me the wrong ones) and make sure the bolt is tightened down well.
Old March 22nd, 2008, 07:39
garr garr is offline
I just repaired my Leaking 01.
Make sure you soak the new "O" rings in fresh motor oil for a little while before installation. The ones on the E-Bolt (The large torx head bolt) need to spin during installation. And tighten it down good, But do not use a 3ft piece of pipe to tighten it down, You do not want to crush the big "O" ring.
I wonder if the large "O" ring is necessary? Would some RTV work in place of it? What do you guys think?
Old March 22nd, 2008, 07:47
Narfxj Narfxj is offline
I once read a post here that a guy did the same thing replaced the O-ring a couple times and still was leaking. In his case the oil pump was bad and was blowing out the new o ring. Hopefully in your case you just got the wrong O-ring. But just in case
Old March 22nd, 2008, 10:49
mramr1974's Avatar
thanks for the info im sure there the right o rings I checked them aginst the originals, i throughly cleaned out the original oings until the adapter sparckeld before i put in the new ones. i did pre oil them . i didnt letem soak though. but i do have that sticker , the filter i have on is what the book calls for, does that mean that sticker makes whats in the book incorrect ?the filter that on it is also the same one that was on it before i changed out the adapter . I guess it could be that simple but how could i tell if the filter is wrong? Im a nubie if you couldnt tell
Old March 22nd, 2008, 10:56
mramr1974's Avatar
i kinda dumbhow doi tell if the filter is wrong ?
Old March 22nd, 2008, 11:12
mramr1974's Avatar
well its not the filter i called the parts store the number on the sticker is the filter i got. i have to just take it apart again
Old March 22nd, 2008, 14:12
Is it leaking from the filter gasket?
where the large "O" ring mates the 2 surfaces?
Or from where the big torx head bolt mates to the adapter?
If it is leaking from the filter gasket it is probably the wrong filter.
Leaking from the other locations & it is probably a damaged or misaligned "O" ring.
Old March 23rd, 2008, 00:58
Yucca-Man's Avatar
Yucca-Man Yucca-Man is offline
NAXJA Member # 683
Leaving the old gasket on the adapter when you remove the old filter will also cause leaking. That's not uncommon, and should definitely be something to look at.
Out of curiosity, just what filter do you have on there? Parts houses aren't exactly sources of reliable information. You've got the horizontal filter, right? That can also trade that out for a larger filter (another 1/2-quart of oil capacity, and additional filter surface area) - http://www.yuccaman.com/jeep/filter.html
So where's the leak coming from?
Jim www.yuccaman.com
Old March 23rd, 2008, 12:04
praetorian praetorian is offline
When I replaced my o-rings my engine dripped oil for another two weeks since the engine was extremely saturated with oil. Also how do you know its coming from the oil adapter? Could it be for rear main seal or valve cover leaking?
Old March 23rd, 2008, 20:39
mramr1974's Avatar
the leak looks like its coming where the filter adapter conects to the block .i couldnot see anywhere where the filter itself was leaking .im just about ready to go out and retest in a bit i think possibly i didnt have the pin in the block lined up in the right hole on the adapter theres two holes there 1 goes no where other goes up to filter i may have had in the hole that go to the filter i preaty sure thats the wrong one the pin just keeps it from moving when you tighten it.
Old March 23rd, 2008, 20:40
mramr1974's Avatar
ps mines just a 5/8 bolt
Old March 23rd, 2008, 22:19
xj2win's Avatar
xj2win xj2win is offline
Soaking the O-rings in oil sounds like a horrible idea, since that's what makes the adapter leak - years of hot oil against them eventually breaks down the rubber.
<br>
OP: If you're using the correct size O-ring and tightening it down correctly, it shouldn't leak. Be sure and clean the mating surfaces while you have it apart, and I'd just go ahead and put a nice bead of high temp RTV around all the O-rings. I've taken mine apart before and couldn't find one size of the O-ring, so I just RTV'd the whole thing really good and drove it like that for about two months before I got time to fix it again, it never leaked during the time.
oil filter adapter shameless defect OEM Tech Discussion 10 June 26th, 2006 16:28
oil filter adapter scotttruhart OEM Tech Discussion 4 March 15th, 2006 18:54
4.0 Oil Filter Adapter REDSWAG OEM Tech Discussion 17 January 23rd, 2006 23:15
89 4.0 leaks oil, pan, filter housing, main RangerRick OEM Tech Discussion 11 December 8th, 2004 15:17
Oil filter adapter? Jeepster4wd OEM Tech Discussion 16 February 27th, 2004 00:15
