Old July 24th, 2019, 20:49
97xj_bandwagon 97xj_bandwagon is offline
Crank, No Start, No Fuel Pump Priming, No Spark, No Gauges
1997 Jeep Cherokee Sport 4.0 AW4 NP242. I was driving the other day and the jeep was running fine and then cut off with no warning. Wouldnít start back up but it would crank. The gauges donít work but the lights in the gauge cluster work. Also the electric fan will kick on every time i turn the key to accessories. I got it home and realized the fuel pump wasnít priming when I turned the key, but the fuel pump relay would click. So i swapped the fuel pump relay with the ASD relay, still nothing. Also checked for spark and it turned out there was no spark. First thing that came to mind was a bad ground, so i cleaned every ground in the engine bay, that didnít work. Next i changed the cps, that didnít work. And then i swapped the ECU, that didnít work either. Any ideas???
Old July 25th, 2019, 18:29
8Mud's Avatar
8Mud 8Mud is offline
Re: Crank, No Start, No Fuel Pump Priming, No Spark, No Gauges
Check the orange wire going to the CPS or cam position sensor for 5 volts with the key in the run position. A partial short in a sensor can cause the input voltage to the cps (or most sensors) to be low and can trigger a no bus situation.
May be as simple as fuse issue, check those first.
Old July 25th, 2019, 18:32
Turned out to be the Fuel pump/pcm fuse.
Old July 25th, 2019, 18:34
8Mud's Avatar
If you aren't getting five volts (some years it is seven) try unplugging sensors one at a time until the five volts (or seven) returns. Start with the cam position sensor. If you have a sensor short and are lucky, the five-volt power supply shuts itself down as a safety measure and there is no lasting damage.
Old July 25th, 2019, 18:36
8Mud's Avatar
A good reason to troubleshoot from simple to hard and from cheap to expensive.
Crank but no start. I can hear the fuel pump running. rc10t4orange OEM Tech Discussion 19 April 17th, 2018 12:31
1991 XJ no crank, no fuel pump, no spark. Xjcrawler736 OEM Tech Discussion 1 June 7th, 2012 08:19
Crank, no start; fuel pump not priming? kujito OEM Tech Discussion 29 July 10th, 2010 11:44
Fuel pump help; crank, no start. kujito Colorado Chapter 0 July 7th, 2010 06:58
spark fuel crank no start doaxj OEM Tech Discussion 13 November 15th, 2003 05:36
