Old July 21st, 2019, 18:35
smcqueen smcqueen is offline
Transfer case failure?
I have a 95 XJ with AW4 auto and NP231 transfer case with Novak slip yoke eliminator. Jeep left me stranded on the highway 30 miles outside of Phoenix. Heard a clunk then no drive. Nothing in 2wd or 4wh. Still rolls in park. Shift linkage replaced and in good working order. I can put in 4wl and it will drive around. No unusual noises at all. Any thoughts?
Old July 22nd, 2019, 03:49
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Transfer case failure?
Are you shifting the from the shift mechanism lever or from the Range Lever on the transfer case ?
You could suppose that the root cause is the shift mechanism being improperly adjusted, or perhaps the shift fork is broken, or the shift fork tabs are worn out. Failure of 2wd and 4x4 Hi is not a common failure.
Originally Posted by bimmerjeeper
People are dumbfounded when I tell them I know how to change the spark plugs on a car.
Old July 22nd, 2019, 11:23
I replaced the shift linkage with the stick shift linkage with the aftermarket type that simply uses two rod ends with adjuster. Have never had trouble with shifts once I got it set up. I looked under the Jeep and saw that it was shifting the range lever. I suspect something internal is a problem and plan on removing the transfer case. Just wondering what to expect. Thanks.
Old July 22nd, 2019, 14:54
Rick.rob Rick.rob is offline
Have a 2004 liberty with the np231, did the same thing no 2wd/4hi but works awesome in 4lo. Took transfer case apart, the mode fork( one towards transmission side) was broke.
Pinion Yoke & Transfer Case, Damage Following Driveshaft Failure - Thoughts? BadHash_NoSum Modified Tech Discussion 9 February 22nd, 2017 21:43
AXLE FAILURE VS U-JOINT FAILURE (PICS) curbdog17 OEM Tech Discussion 8 February 15th, 2009 16:49
1990 AW4 242 transfer case - 1990 5sp 231J transfer case input gears..... TRNDRVR OEM Tech Discussion 1 November 28th, 2008 21:12
231 Transfer case rockhead SoCal For Sale 0 April 25th, 2008 08:30
Transfer case shifter bezel from a 242 transfer case Cue-ball Wanted: Private Party Only 2 June 11th, 2004 14:58
