Old July 18th, 2019, 12:59
tech1001 tech1001 is offline
Re: Unexplained coolant loss, but mechanics thinks the head is fine. ???
If your oil pressure is still good change the head before any real damage happens to the bearing .
Old July 18th, 2019, 14:57
Tony the Liger Tony the Liger is offline
It sits between 40-50 at start-up, then settles down to 12-15ish while idling. Tbh, I've never known what's typical for an XJ.
Old July 18th, 2019, 15:01
asymptonic asymptonic is offline
That's okay if its a hot idle. Basically minimum spec. But if you're getting that at cold idle and it goes below that, you probably have bearing damage.
1998 4.0 I6, AX15, NP231
Old July 18th, 2019, 16:57
trippled trippled is offline
What oil you running? 10w30? I agree I'd just throw a head on and run it. Could go for a long time before any other issues with the bottom end arise.
Coolant Loss...... ChiefGunner OEM Tech Discussion 3 June 15th, 2016 12:57
Coolant Loss GreenXJ2K OEM Tech Discussion 16 February 22nd, 2010 15:36
2000 xj classic coolant loss Skullver OEM Tech Discussion 8 August 23rd, 2005 18:40
Bad Coolant Loss BIGSLVRXJ OEM Tech Discussion 19 June 23rd, 2004 09:03
(94) 4.0 LTD Coolant loss-weird SIBERIAN82 OEM Tech Discussion 4 June 3rd, 2004 06:36
