Old August 19th, 2013, 14:43
YFZsandrider YFZsandrider is offline
replaced heater core, now blower motor problem
I just went through all the work of pulling the heater box to replace the heater core and evaporator, after getting it all back together, I took it by the ac shop to have them service the system, not even thinking to make sure the heating and cooling functions work first....
Long story short, they filled the system with refrigerant, and when they went to test it, the fan wouldn't come on and the blower motor started smoking.
What could it be?
Old August 19th, 2013, 16:25
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: replaced heater core, now blower motor problem
All anybody else can do is guess as to the actual cause. You need to perform an inspection of the switch, wires, relay, fan motor, and resistor. Look for melted stuff.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old August 20th, 2013, 07:00
Rod Knee's Avatar
Rod Knee Rod Knee is offline
Other than the smoking blower motor I had the same problem about a year ago. Had to take it to a dealer an hour away because neither I or my regular mechanic could figure it out, but it turned out to be the switch.
Old August 20th, 2013, 10:28
Any good info on a testing procedure for the fan motor, relay, and switch would be greatly appreciated!
Old August 20th, 2013, 18:35
Well, I pulled the resistor, and it smelled absolutely fried, so I replaced it. As as soon as I install the new one, and turn on the heater, no fan, and smoke starts coming from the heater box again. Any Ideas?
Old August 20th, 2013, 19:26
joe_peters joe_peters is offline
Yep.
Pull the blower motor and then hook it direct to the battery--sounds like it is fried.
Blower issue, replacing heater core what else? TB2Blazer OEM Tech Discussion 7 October 25th, 2012 22:27
Heater Core Replaced - aluminum unit spitfyre OEM Tech Discussion 14 November 22nd, 2011 13:06
Just replaced Heater Core, now my blower motor doesn't work ColdSmoke OEM Tech Discussion 3 October 28th, 2010 18:30
Heater Core / Blower Motor Write up 1985xjlaredo OEM Tech Discussion 3 October 10th, 2007 09:28
Blower motor not working. replaced motor and resistor...Searched can you help? 99xjclassic OEM Tech Discussion 12 May 4th, 2007 21:31
