Old October 8th, 2019, 12:23
truckeejeeper's Avatar
truckeejeeper truckeejeeper is offline
Jeep Horn Relay on a 1991
So, I've searched for the answer to this question before... but never got a definitive answer. Where is the horn relay on a 1991 XJ? I've gotten answers for 1995s, 1987, 1999s, Grand Cherokees (yuk) but never seem to get an actual answer for 1991. I've having a lot of problems with the horn and would like to check the relay. But where is is it???
Most answers I've gotten have been a) In the engine compartment fuse/relay box (Is is not there) or b) some vague description of somewhere under the drivers side dash. I have not found anything there.
Anyone got the real answer?? Photos would be epic.
Much thanks to anyone who can help!!
- TJ
1991 4.0 Sport 5speed 4x4
Old October 9th, 2019, 01:49
tech1001 tech1001 is offline
Re: Jeep Horn Relay on a 1991
I don't know where it is but if you unplug the horn maybe you can hear it click and find it that way .
Old October 11th, 2019, 08:07
lawsoncl lawsoncl is offline
Have a look at:
https://www.cherokeeforum.com/f2/91-...ocation-82694/
Old October 28th, 2019, 10:50
So, thanks for the replies. And thanks for the link, lawsoncl. I've read that thread, and there is a photo of his jeep, under his dash. It shows, down by the hood release latch, a strip of 3 relays, and the one on the left is the horn relay.
The problem is, I don't seem to have that strip of relays under the dash there. I have spentquite a bit of time under there digging around and don't see anything that looks like the metal hanger or the 3 relays.
Maybe it's just right in my face and I'm losing my mind...but I'm still in search of the mythical horn relay on a 1991 XJ (4.0, 4x4, 5sp., sport)
Anyone actually ever seen this unicorn with their own eyes?
thx y'all
Old October 28th, 2019, 12:13
Re: Jeep Horn Relay on a 1991: FOUND
Omg..found it.
For anyone looking: It's waaaay back there, under the dash, just left of steering column if you are sitting in drivers seat. It's hard to see unless you take apart dash or get waay under there with a light, lying on your back, like with the back of your head on the pedals looking back towards drivers seat. It's a strip of 3 relays (mine were black relays), it's tucked under a metal flange, but pulls out easily to hang down on its wires. Mine only had two relays in. Horn relay was the one one the end.
SO stoked to replace this. My horn has been going off intermittently, and that is not a fun way to drive.
Thx for the help Naxja
99 Horn Relay Karlito OEM Tech Discussion 0 June 21st, 2009 10:21
95 XJ - Horn relay location? Blaine B. OEM Tech Discussion 2 January 4th, 2008 16:12
Horn Relay? (Horn off with Ignition Off) 90XJ RickyN29 OEM Tech Discussion 2 September 10th, 2006 06:17
horn relay ChipsXJ OEM Tech Discussion 1 January 8th, 2006 17:09
Horn Relay? BigDadys94xj OEM Tech Discussion 1 January 4th, 2005 08:35
