Old October 3rd, 2019, 20:45
AIDANMELAD AIDANMELAD is offline
Drum sizes
Hi guys, my 2001 XJ Limited,had some rotted brake lines. Replaced them, then found out the wheel cylinder's are shit. My Jeep is upstate, I'm in the City, How can I tell what size drums my Jeep has...TIA!
Old October 3rd, 2019, 20:52
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Re: Drum sizes
Every XJ I have worked on had 9" drums but Rock Auto shows a 10" drum, used in police cars.
Measure the outside diameter of the drum. If it is almost 11", it's a 9" drum. if it measures 12-1/2" in diameter, it's a 10" drum.
Specs taken from Rock Auto's site.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old October 3rd, 2019, 23:24
Ralph77 Ralph77 is offline
Re: Drum sizes
Chances are it is a 9" drum.
Ways to tell.
9" drums are not finned. 10" are.
To further confirm.
The wheel cylinders.
With a 9" set up the wheel cylinders for each side are the same. The brake line goes straight in.
With a 10" set up the wheel cylinders are different for right and left. The brake line comes in at an angle to each.
Old October 4th, 2019, 03:33
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Drum sizes
9" drums are smooth, 10" drums are finned.
People are dumbfounded when I tell them I know how to change the spark plugs on a car.
Old October 4th, 2019, 06:37
techno1154's Avatar
techno1154 techno1154 is offline
Re: Drum sizes
I think the Dana's had the 10" diameter drums and narrow/er shoes while the 8.25 have 9" drums and the wide shoes.
https://www.naxja.org/forum/showthread.php?t=1053079
I just went back in the archives. I remember this being discussed years ago.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old October 4th, 2019, 19:28
lazyxj's Avatar
NAXJA Member #1310
Re: Drum sizes
9" drums have 2-1/2" wide shoes, 10" shoes are 1-3/4" wide.
Good to know that 10" drums have fins.
Old October 5th, 2019, 09:05
Joeygo Joeygo is offline
Re: Drum sizes
This is what I have sitting in the garage. D44 10" finned drum 2 1/2" shoes.
Old October 5th, 2019, 09:19
RCP Phx RCP Phx is offline
Re: Drum sizes
I had the "big" (10 x 2-1/2") brake package on my D44.
Old October 6th, 2019, 07:14
jbeintherockies's Avatar
jbeintherockies jbeintherockies is offline
Re: Drum sizes
1. If my 2000 XJ limited has the 9" drums, can they be replaced by the 10" drums?
2. Is it worth the swap? Has anyone done it? Would you do it again?
I just picked up an 8.25 off craigslist for $100 and I need to go through the drums. Wondering if an upgrade is worth doing. I've read mixed reviews about rear discs. Sorry, I didn't mean to hijack the thread. Just providing background as to why I am asking about the drum swap.
TYIA
Old October 6th, 2019, 07:25
ehall's Avatar
ehall ehall is offline
Re: Drum sizes
answer is to measure the inside diameter of the existing drum, or if you don't have those to measure the diameter of the backing plate
almost all XJs had 9" so it is the safe default assumption. you will know right away if its not right
my '91 beater rebuild
Old October 6th, 2019, 12:01
Tim_MN's Avatar
Re: Drum sizes
Originally Posted by jbeintherockies View Post
.... 9" drums, can they be replaced by the 10" drums?
Most likely, yes.
IMO, if you are going to change anything, go with disk brakes. KJ Liberty disk brakes are about as close to bolt on as you can get.
Old October 6th, 2019, 12:07
Re: Drum sizes
Originally Posted by Tim_MN View Post
Most likely, yes.
Amen to that, if you change drums you have to change the backing plates and wheel cylinders also.
Old October 6th, 2019, 13:14
techno1154's Avatar
Re: Drum sizes
Most likely, yes.
I am totally with these guys'. If you are ion through all that work, go with disks.
I do not know wat you heard but,... I did not set any breaking improvement going from a good working drum brakes to discs. However, other benefits include maintenance free over the years and better break pedal feel which adds to the comfort feeling when a panic break application is needed.
Patrick
#594
29 spline 8.25 drum to drum w/ trac lock + extra shaft zacattack SoCal For Sale 0 August 24th, 2007 23:07
XJ rear Dana 44 axles complete drum to drum for sale 1toughxj Arizona For Sale/Wanted 10 February 5th, 2007 09:46
XJ rear Dana 44 axles complete drum to drum for sale 1toughxj For Sale: Private Party Only. XJ ITEMS ONLY 15 February 5th, 2007 09:46
Dana 44 Jeep Cherokee XJ Complete, Drum to Drum, San Jose, CA $500 RickyN29 For Sale: Private Party Only. XJ ITEMS ONLY 7 October 19th, 2006 03:31
Drum sizes? T.Hopp OEM Tech Discussion 2 February 1st, 2005 14:57
