Old July 20th, 2019, 14:17
gdl90xj gdl90xj is offline
New steering box - too soft ?
I searched but could not find an answer, sorry if it has been discussed before
I had a very leaky steering box, it is now replaced by a remanufactured unit
Boy ! Steering is now awfully soft!
Got an alignment, added shims to increase the caster 2° but still soft, it drives in straight line smooth and no vibrations.
I can drive with one finger, I can not remember how it was when stock , but I do not recall it feeling like a 1970s power steering sedan like a ford ltd.
I have a 2" suspension and all terrain 235/75/15 tires
so the question is, and I understand it is hard to judge without driving the car, but is this steering softness normal ?
Thanks in advance
Old July 20th, 2019, 14:39
trippled trippled is offline
Re: New steering box - too soft ?
Probably something wrong in the box. They should have some feel to them. Seen a couple do that. What brand did you get?
Old July 20th, 2019, 18:29
brand .. hmm I don't know, it is an original box from another xj
Old July 20th, 2019, 18:50
lawsoncl lawsoncl is offline
I'm not sure what you mean by soft. There were a couple different gear rations used over the years so it might just be a different in the gear ratio.
Old July 21st, 2019, 05:54
Thanks I know it is difficult to explain
soft as there is no resistance at the steering wheel when turning, there is little feel of the road, as if the wheels were lifted of the ground
there seems to be to much power from the hydraulics
the steering works fine, it is just to easy to operate, sneezing at highway speeds is now a dangerous thing to do
Old July 21st, 2019, 09:47
Black1990jeep Black1990jeep is offline
Sounds more like an alignment issue, the vehicle not tracking well. have the alignment checked.
Old July 21st, 2019, 16:28
No. He said it changed after the replacing the the box. It has to do with the valve in the box.
Old July 21st, 2019, 16:53
A valve in the steering box,... I guess not accesible from outside?
And I checked the alignment, added 2° of caster, it centers better and tracks in a straight line very well
Old July 21st, 2019, 18:04
I thought by sneezing on the highway issue that it tended to take off and wander.
Valves are under the outlet port, can be removed with pumps installed Too much pressure could over drive the system, making light easy steering.
also make sure your tire pressures are not too high, that too can cause light steering.
Old July 23rd, 2019, 05:06
denverd1 denverd1 is offline
Sounds like a good thing to me
WTB Soft 8's Bstd_02_Wgn NAC Classifieds 10 October 24th, 2008 17:00
soft 8's impetus-93xj OEM Tech Discussion 3 January 14th, 2008 09:04
How soft should my steering be? smcdonaldaz OEM Tech Discussion 17 December 31st, 2007 05:25
Soft top 94XJ4x4 Modified Tech Discussion 17 April 14th, 2005 12:37
CJ5 soft top and soft doors... Benz0 Wanted: Private Party Only 3 January 30th, 2004 09:13
