Old July 14th, 2019, 12:08
Dalton99xj's Avatar
Dalton99xj Dalton99xj is offline
1999 4.0l engine noise? Maybe you know?
I have a 1999 XJ 4.0l AW4 4x4. 4Door. This jeep was sitting for 5 years. I put a battery, champion plugs, cleaned throttle body, TPS, IAC, MAP sensors. Also ran a little bit of seafoam through throttle body. Dumped rest in full tank of gas. Ran jeep for a few days. Then went on a 200 mile trip. About 100 miles in jeep went from 55 - 60 to a whopping 20mph. And very little power. I got to my destination the next morning went to start it up. There was a tapping noise. And if I brought the idle up above 2500 rpm it makes a rattling noise. I cannot figure out from where. I have a video of the start and sound.
https://youtu.be/_bVXex4YACM
Sent from my 9027W using Tapatalk
Old July 14th, 2019, 16:08
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: 1999 4.0l engine noise? Maybe you know?
Is or was the Check Engine Light ON ?
What caused the loss of power, fuel issues, engine sensor issues, or mechanical issues ?
Approximately where is the noise coming from ? Is it a valve lifter, piston skirt, broken motor mount, basic engine misfire, or flex plate noise ?
People are dumbfounded when I tell them I know how to change the spark plugs on a car.
Old July 14th, 2019, 16:33
tech1001 tech1001 is offline
To me it sounds like maybe the fly wheel broken .
Old July 14th, 2019, 16:57
Tim_MN's Avatar
AW-4 makes it a flexplate. Cracked flexplates and loose flexplate bolts are somewhat common.
Old July 15th, 2019, 20:43
Dalton99xj's Avatar
Not sure on the power loss. Did find a line that was bad on the fuel line that connected to a box under the jeep in front of the fuel tank.
Ill have to look at the flexplate maybe it broke and only catching some of the time....
Sound seems to be coming from lower engine area but could be flexplate area.
Yes i need new motor mounts. Seen that today.
Transmission mount in good shape.
Old July 15th, 2019, 22:56
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
I believe that box is a charcoal canister, how is your line bad?
An engine stethoscope at Harbor Freight may be helpful to you, it's like four bucks. it works pretty good.
Not sure what you think could be happening on the flexplate, all it engages is the starter. It's bolted to the torque converter/ crank shaft. If it's not catching there you wouldn't have a running vehicle likely.
The sound is frequent and without seeing metal on metal mount contact I'm leaning elsewhere.
Can you get a clip underneath?
Old July 16th, 2019, 20:36
Runnin'OnEmpty's Avatar
Runnin'OnEmpty Runnin'OnEmpty is offline
A clogged catalytic converter will slow a vehicle down like yours did.
They also get very hot, sometimes red hot, and can also develop a
rattle after they cool off...
An engine that's run low on oil can seize.
it's possible the oil screen pick-up was clogged and starved the engine
of oil on the trip...especially since it sat for so long. (5 years?)
1999 AC compressor noise? Ax15xj OEM Tech Discussion 5 May 15th, 2017 16:55
engine noise lifter noise or.....help cz94xj OEM Tech Discussion 10 January 19th, 2015 14:50
1999 engine block echo4victor OEM Tech Discussion 7 September 19th, 2011 16:17
FRONT END NOISE 1999 JEEP XJ 4X4 SPIKEHORN OEM Tech Discussion 4 November 5th, 2006 16:13
1999 xj engine want's to die while driving judah304 OEM Tech Discussion 0 August 5th, 2003 09:41
